I installed FDS PRM as single user only but I'm owning a network license (ok, I should have known 😉 ).
Is it possible to change the type of license after installation or do I have to reinstall it?
That wouldn't be that great as this takes ages and reinstalling plugins, too..
Additionally I'd like to know if I can use the english version with my german license.
I was told so by my distributor, I just want to be safe before installing the wrong version.
Thanks in advance,
Niko
Solved by y-p. Go to Solution.
Hello Niko,
Yes, you can change the license type without reinstall.
For Autocad, you can change the value to switch between standalone and network.
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B004\AdLM]
"Type"=dword:00000002
1: Network
2: Standalone
3: Multi-seat Standalone
For Inventor, you need to change the several key to switch between standalone and network.
For network:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor
RegistryVersion17.0\ADLM Type = 1
RegistryVersion17.0 LicenseMode = 1
RegistryVersion17.0 LicenseType = Network License
RegistryVersion17.0 StandaloneNetworkType = 3
For Standalone:
RegistryVersion17.0\ADLM Type = 2
RegistryVersion17.0 LicenseMode = 2
RegistryVersion17.0 LicenseType = Stand-Alone License
RegistryVersion17.0 StandaloneNetworkType = 1
-Xuesong
Hi Xuesong,
thanks for your effort.
As I had many components of FDS PRM installed I probably would have had to change the registry in all cases.
Anyway I uninstalled the whole suite and reinstalled only 3DS now as this is my main component.
Now I'm getting the -15.570 error about obtaining license..
I followed Travis' help about the IP4 disabling from here: http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982... but had no luck. I changed the hosts file and deactived IP6 as well..
So I'm a bit lost right now- may it be related to the fact that I have the german license as mentioned above but installed the english version?
Since this may be the case I'll leave it in this thread for now- but probably it would be better to start a new thread soon as the title does not represent the actual question anymore...
PS: I'm on a Win 8 system btw.
