Factory Design Suite General Discussion
Active Contributor
0 Kudos
Post 1 of 2
Cannot change asset properties in AcadM, only in 3D Inventor
146 Views, 1 Replies
09-10-2012 09:53 AM
When I insert assets in the Autocad, my asset property is open but empty. Even when I select an asset on the screen. The only way I found the change values is in Inventor, but really, I would like to be able to change it in Autocad. This is with r2013. Does anyone had this problem?
Employee
55 Kudos
Post 2 of 2
Re: Cannot change asset properties in AcadM, only in 3D Inventor
09-10-2012 05:47 PM in reply to: patrick.fillion
The only way that you willl be changing the parameter values for asset in AutoCAD is to use variants.
Please refer to anther same topic http://forums.autodesk.com/t5/Autodesk-Factory-Design-Suite/Changing-Asset-Properties-in-ACADA-or-AC....
-Xuesong
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
