Factory Design Suite General Discussion
Active Contributor
LukeDavenport
Message 1 of 2 (137 Views)
Can you customise the Report generated from AutoCAD (Factory Design Suite)
137 Views, 1 Replies
02-02-2012 05:00 AM
I am looking to edit the fields that appear in the automatically generated utilisation report from AutoCAD. Perhaps to add a company logo also. Is there any way that this can be done?
Many thanks for your help
The template used to generate the report is located in %ProgramData%\Autodesk\Factory Design Suite 2013\Support\OptimizationReport.xlt. You should be able to edit that template to add some customization.
Yizhou
Employee
yizhou.cao
Message 2 of 2 (132 Views)
Re: Can you customise the Report generated from AutoCAD (Factory Design Suite)
02-02-2012 08:04 AM in reply to: LukeDavenport
Yizhou
Yizhou Cao
Autodesk Factory Design Suite team
