Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Can a connector point to be consumed more than once?
4 REPLIES 4
607 Views, 4 Replies
Just wondering can a connector point to be consumed more than once?
Thanks.
4 REPLIES 4
XuesongBai
Hi there, Connector be consumed only one time. Do you have any special purpose on this? Thanks, -Xuesong
Please mark as a solution if somehow I got it right.
in reply to: XuesongBai
Hi Xuesong,
Thank you for your quick reply. Yes, easpecially when i am working on traffic barrier project.
Please see attached picture - the connector point on the rail has been consumed by the post. But I need the same connector to locate my fist tail end to finish the railing systems.
Thank you.
JoAnn_Hogan
In special cases like this one, maybe you could place a normal mate constraint on the parts? Or maybe have a second connector point?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
XuesongBai
in reply to: JoAnn_Hogan
I also recommend as Jo that you can create second connector on the right position. Thanks, -Xuesong
