I want to build a chain asset in the Factury Asset Warehouse.
I upload a part.
Then i push the Build asset chain button and agree.
Then nothing happens.
I do the steps with WikeHelp.
Do i forget something.
See the link.
http://www.screencast.com/t/IpA4JskH
Hi jostroopers,
Could you check with your system time whether correct with time zone? We meet the same error if the system is incorrect.
Jorge
I live in the Netherlands so my time zone is Amsterdam.
Should thate be a other zone?
Seems your time zone is correct. Actually this is not asset chain issue, it is "Terms of use" issue, I think you also cannot do other operation (such as upload file) right?
If your time zone and time is correct, you can try again to see if the issue still exist (Reboot browser firstly). If yes, I am afraid you have to new another account to have a try.
I can upload files.
I did try it at my company with another login and it works.
Now at home i tried with the other login and it works and after that i login with the first login and now it works.
Thanks for the tips.
Hi Jos,
That is great that is working for you.
Don't hesitate to post any question when you customize your chain asset by the tool.
-Xuesong
Thanks Xuesong.
I will, because we want to use the chain asset for our products.
But it's not easy, i tried last night and it didn't work yet.
There is not much white paper or turorials exept the wiki and that isn't much clearly.
Just the little things you can not find in the wiki.
Isn't there a step by step how to do things.
Hi Jos,
I wrote some tutorias of how to customize the asset chian asset. Please look at the details that are shared at Autodesk 360(http://a360.co/19zl81M)
BTW: you can share the assets with me in FAW, so I can help you create some sample.
-Xuesong
Xuesong
I let you know.
Thanks, youre the greatest.
