Hello there,
to use a 3D DWG as an overlay works fine, yet I would want to render it alongside
the FDS geometry I am using. Is it possible to do this? Would spare me the nuisance
to import the 3D DWG... It´s faulty in most cases and requires extensive amounts of
time.
I´d be glad if it was possible to add display options for the overlay. In raytracing mode
at least unshaded wireframe geometry is shown.
Kind regards
Daniel
Hi Daniel,
The overlay stuff is only the graphic rendering, not the real geometry. So it is not possible to render them along with the FDS.
-Xuesong
Hello Xuesong,
thanks for clarifying. The issue has been with objects I needed to convert to
mass elements in ACAD first. The IGES is okay, but some of the bodies could
not be converted. Someone used a non compatible modelling method. Basi-
cally only Navisworks and it´s respective FBX export work flawless. Therefore
I tried to reproduce this conversion with Inventor´s capabilities, yet I´ve not
been successful with this endeavour. Even the DWG overlay fails with those
elements.
I am about to recommend to keep those parts seperate and only combine
them in Navisworks to achieve the maximum visualisation quality for the
process.
Can you recommend another way? I´d be able to send you the sample data
we need to include if you like to.
Kind regards
Daniel
P.S.: Tailoring sentences to be blocks really helps to put me into action.
