We are currently looking at redesigning our splitter fixing for welded ductwork by setting up a "tab" on the side of the splitter which would be welded to the bend - in our case a 50mm wide tab at no more than 150mm centres.
Currently the only option to determine the number of tabs is a "Tab Quantity" field in the splitter setup. Splitters can be of any length so a quantity would have to be determined for every splitter based on the length. What I would like to see is a setting for "Maximum Pitch" so the splitter can calculate the number of tabs based on this value, ensuring the pitch of the tabs will not exceed that value.
