At times, when you are bringing in content from the Revit Model, a particular run may be segmented into multiple lines. When brought into CAD/EST via "PROCESSRUN", you have to adjust each entry to your standards then click OK to fill them.
You would then need to combine those desgin lines manually. Can we get an option added to the "Revit Process Mapping" window that displays a checkbox that states "Combine Design Lines". When checking this box, it would automatically combine all the lines within the window, saving you much time.
Can we also get the first line to automatically be active upon clicking OK?
It would also be nice to have an "Isolate Objects" checkbox added as well. Upon clicking OK. It would Isolate the objects and thier desgin-lines you are bringing in through "PROCESSRUN"
Nick
