Show only
Search instead for
I would like the Dimension Spool tool to pick up your current snap settings. Currently it changes my snaps and I have to rightclick then select the snap I need... over and over. It's a lot of extra clicks.
It does at least let you customize the dimension snaps it activates when the spooldim command runs. You can lookup the snap bit codes for OSMODE system variable and use that same value in the spool.ini.
The defualt in set to 11.
I set mine to 10 to just shut off the end point snap.
We use different snaps depending upon the task. It would be nice to have the dimension tool pickup your current settings, rather than default to a setting.
