Many people's mind work off of Feet & Inches when inputing in Elevations. Having to convert that to a decimal value so that the software can read the elevation is an EASY step but it is also an EXTRA one as well. If you toggle the "Enter Imperial Dims in (ft)" setting on within the database, it fixes this issue but it also changes the input of the dims within a fitting. Could we get the dims and the elevations to be two different toggle settings?
Thank you for your consideration,
Nick
