Can we get an option to change the elevation of existing runs?
Currently you must isolate-> activate the designline-> select line -> Edit-> Select desired entities-> then change the desired elements elevations-> and refill 3D.
Once we've moved past what the designline can provide and it's abandoned. It would be nice to be able to select button to change elevation (example: -12" or show the elevation and type new elevation) -> then fill between 2 points to make up the connections.
