In CADmep, when utilitzing the command "CHSPEC" you are given the options to "Auto Repair Straight Lengths" and "Don't Allow Template Fittings to be Stretched" (See attached)
As of right now, you have to open your drawing in CADmep, perform the CHSPEC then CREATECAM your job back out, or fix items manually while in CAM / EST.
Can we get this functionality added to CAMduct and ESTmep please? It would save time when having to change specs on items that have different standard joint lengths.
Nick
