Fabrication CADmep Forum
Welcome to Autodesk’s Fabrication CADmep Forums. Share your knowledge, ask questions, and explore popular Fabrication CADmep topics.
What is the command to report all CID's?
5 REPLIES 5
willweaver
1442 Views, 5 Replies
At AU2013 Andy showed a way to bring up all CID's. I think it was something you type in the makepat command. Does anybody recall what the command was?
5 REPLIES 5
in reply to: willweaver
I believe it was MAKEPAT *.
willweaver
I tried Makepat* and Makepat <Enter> * and it did not work. It says "Requires a positive nonzero integer."
I just checked with someone else who was there and it's MAKEPAT ALL but it doesn't work in CAD.  I think they were in CAM when they showed us that
davidronson
Get a hold of Enceptia...they have an updated list of CID's.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
Yes, MAKEPAT ALL only works in CAM.
