I'm using Fabrication CADmep 2015 and I made an offset that had a restricted flow. I pushed past the warning and the attempted to move the fitting. The warning about restricted flow appeared again but now I can't get past the warning. I can't modify the fitting to relieve the restriction because the program is stuck in a warning loop. How do I get control again?
