Fabrication CADmep Forum
Welcome to Autodesk’s Fabrication CADmep Forums. Share your knowledge, ask questions, and explore popular Fabrication CADmep topics.
output to cam data
3 REPLIES 3
ArtisanCAD
646 Views, 3 Replies
output to cam data
In fabrication every time I select objects to output to a cam file I get the message "the following items will not be output" (see attachment).. and  the operation is cancelled... does anyone know why this is happening?
Lorne
3 REPLIES 3
davidronson
in reply to: ArtisanCAD
Have you already sent it to CAM? If so, it wont resend the same item to CAM unless you reset the Status back to Design.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
ArtisanCAD
in reply to: davidronson
It was because there were no entrys in the status field in the main database!
apparenly you need at least one entry!
thanks for pointing me in the right direction!
Lorne
davidronson
I learn new things about this program almost every day. Keeps you on your toes. Glad I could help!
