In fabrication every time I select objects to output to a cam file I get the message "the following items will not be output" (see attachment).. and the operation is cancelled... does anyone know why this is happening?
Solved by ArtisanCAD. Go to Solution.
Have you already sent it to CAM? If so, it wont resend the same item to CAM unless you reset the Status back to Design.
It was because there were no entrys in the status field in the main database!
apparenly you need at least one entry!
thanks for pointing me in the right direction!
I learn new things about this program almost every day. Keeps you on your toes. Glad I could help!
