Just updated to Fab 2014 CADmep from MAP 2009.
i can no longer use the command maplogout, what is the new command to access these profiles?
Thanks!
Thanks for the reply. I actually figured it out right after i posted. Sort of.
The problem was with the Autologin. Once someone is logged in, and checks the box to always login, MAPLOGOUT doesn't do anything. If you don't check the box, MAPLOGOUT works fine.
Heres where i got started:
Any ideas on how to fix the re-login issue? I consider this fixed for now, but trying to switch users on the fly is kind of a pain.
Thanks again
