hi there
I have problem with the size of the size texts ,they are too much small, I've changed the "Model space text size ' in annotation, cad setting, take off but it didin't work and also I changed the text height in autocad mep but nothing happend and they don't became bigger...
best regards
Solved by gorlewskia. Go to Solution.
Did you try typing in "TEXTSIZE" and then you can type in the text size you are looking for. After you change the text size just make sure to do a regen.
thanks alottttttttttttt!!!!!! it works ,would you plz answer my questins in est mep categeory also?
