Fabrication CADmep Forum
Welcome to Autodesk’s Fabrication CADmep Forums. Share your knowledge, ask questions, and explore popular Fabrication CADmep topics.
how to get a size text in appropriate size?
3 REPLIES 3
faranakasadpour
1382 Views, 3 Replies
hi there
I have problem with the size of the size texts ,they are too much small, I've changed the "Model space text size ' in annotation, cad setting, take off but it didin't work and also I changed the text height in autocad mep but nothing happend and they don't became bigger...
best regards
3 REPLIES 3
in reply to: faranakasadpour
Did you try typing in "TEXTSIZE" and then you can type in the text size you are looking for. After you change the text size just make sure to do a regen.
Sorry forgot to mention make sure you are in model space when you type in "textsize" and make sure in model space when you do a regen as well
faranakasadpour
thanks alottttttttttttt!!!!!! it works ,would you plz answer my questins in est mep  categeory also?
