I was changing some settings in my Database\CAD Settings\Annotation. Under Number Text I changed my Text Style from STANDARD to Default and now that I want to change it back, STANDARD is no longer there as an option. How do I get this back?
Basically my leaders disappeared in default and I don't know how to get them back. I just know they were there when STANDARD was my Text Style Setting.
Solved by cam-nav. Go to Solution.
Textstyle in the database needs to match a DIMSTYLE to have leaders active. This is where they are pulled from.
You can just type in STANDARD in the database to get back to where you were.
I actually tried tyoing in STANDARD but unfortunetly it did not work. Now that I know the Text and DIM Styles have a relation to them I want to just change my DIM Style to default. I have a huge project due today so this Test will have to wait. Thanks!
Is there a way to update the model once I have made changes into the database? Simply typing regen doesn't work.
Type REBUILDALL
If this doesn't refresh the leaders try: MOVE > Enter > Enter > Enter then UNDO, this will refresh the leader head sizes and things that didn't with REBUILDALL.
Hope this is in time. 🙂
