AutoCAD fatal error’d to the point where AutoCAD no longer would open. So I went to the windows start menu and reset to default. Used Appload to add CADmep 19x64.arx to the startup suite. modified my pgp file, added a custom toolbar...
How do I add the Ribbons/toolbars back? The only one I have access to is the main one activated by TBAR. (it loads automatically)
When I right click in the gray area I have available toolbars for fusion, express, AutoCAD, and AutoDeskseek
As a side note I lost my Bluebeam ribbon too.
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/1264803
David Ronson told me how a long time ago.
search in windows for cuix and use MENULOAD in autocad.
THANKS DAVID.
If you had a Ribbon, then it was custom. Our tools are primarily accessible through tbar and usesystems
sorry that is what i meant, i hate the ribbons. thanks for the wording clearification. the other toolbars were not available until i added the .cuix it did not add automatically when i added the .arx as i thought it would. someone else usually sets up my machine.
