Fabrication CADmep Forum
Welcome to Autodesk’s Fabrication CADmep Forums. Share your knowledge, ask questions, and explore popular Fabrication CADmep topics.
Fabrication CadMEP Ribbon
3 REPLIES 3
1014 Views, 3 Replies
AutoCAD fatal error’d to the point where AutoCAD no longer would open.  So I went to the windows start menu and reset to default.  Used Appload to add CADmep 19x64.arx to the startup suite.  modified my pgp file, added a custom toolbar...
How do I add the Ribbons/toolbars back? The only one I have access to is the main one activated by TBAR.   (it loads automatically)
When I right click in the gray area I have available toolbars for fusion, express, AutoCAD, and AutoDeskseek
As a side note I lost my Bluebeam ribbon too.
3 REPLIES 3
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/1264803
David Ronson told me how a long time ago.
search in windows for cuix and  use MENULOAD in autocad.
THANKS DAVID.
brett.stacks
If you had a Ribbon, then it was custom. Our tools are primarily accessible through tbar and usesystems
Brett Stacks
Product Manager, MEP Fabrication
Autodesk, Inc.
in reply to: brett.stacks
sorry that is what i meant, i hate the ribbons.  thanks for the wording clearification.  the other toolbars were not available until i added the .cuix it did not add automatically when i added the .arx as i thought it would.  someone else usually sets up my machine.
