Show only
Search instead for
If your 3D model needs connectors, use a block called "condef" to define the connectors. Execute "convert3dmodel" then "savetofolders".
______________________________________________ Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given. || LinkedIn || LinkedIn Fabrication Group ||
