Hi
We have just updgraded to 2015 and have Fabrication 2015 also.
If I open one of our previous (2013) Fabrication drawings, and then load in the cadmep20x64.arx plugin, we are good to go.
However if I then put that cadmep20x64.arx in the startup suite, and restart AutoCAD, when the loader gets to loading the cadmep20x64.arx plugin, the boot hangs and the only way to resolve it is to task manager>end process, as for some reason it's not showing in the Applications tab (probably because it's not classified as an opened application at this stage)
This is happening on all our seats and the only work around for now is to manually load in the application each time.
I noticed there was another thread with a similar issue but it came to no resolve. Is there any solution to this issue?
Many thanks in advance
This has been an issue for some years. I have yet to find a solution apart from taking it out of the start up suite. Sorry!
Thanks for the reply
That's decidedly not cool. How does one make Autodesk aware, or is there not really any point?
Thanks again
G
It doesn't happen everytime here, so never bothered reporting it. The work around is too easy so I can't imagine they would spend the time trying to fix it.
