I am tring to swap out all my gored elbows with pressed. I have pressed in my services and was told that I need to change the details in my button mapping. Can someone help me with the process of changing this?
Solved by idesignher. Go to Solution.
Solved by davidronson. Go to Solution.
Not sure that you really need to change the button mapping. What do you think of the below?
In the Edit Service Template, right click on the pressed, click the "+" button, place the gored elbow, click on the pressed eblow, and select the "-" button.
No, its just swapping out one bend for another.
Ok, thanks. Well that didn't seem to work so well for me, not sure if I did it right but what I found out is that I just had to include what i wanted to fill in and exclude what I didn't.
More than one way to skin a cat.
I did get this to work with other parts needed, it just took a little time to properly understand, so thank you!
