Fabrication CADmep Forum
Welcome to Autodesk’s Fabrication CADmep Forums. Share your knowledge, ask questions, and explore popular Fabrication CADmep topics.
Center line
9 REPLIES 9
Message 1 of 10
btngpnoy
3260 Views, 9 Replies
Center line
We are recently upgraded to Autocad 2014 Fabrication (CAD Mech). Before we upgrade to 2014 we can check/see the centerline of the pipe by placing the cursor on the pipe. Now on 2014 it changed to Top & Bottom info elevation instead of CL is there a way to change this back to center line? thanks in advance.
9 REPLIES 9
Message 2 of 10
btngpnoy
in reply to: btngpnoy
still can not find the solution.
Message 3 of 10
cadbob
See attached PDF for LEVEL BLOCKS. I named mine CL.
I don't believe you can do today's job with yesterday's methods and be in business tomorrow.
Message 4 of 10
Nicholas.Hyland
Hi btngpnoy,
If you’re not using cadbob’s suggestion of Level Blocks I’d suspect the “Same setting for Round” is enabled as per the attached.
Nicholas Hyland
Message 5 of 10
cadbob
in reply to: Nicholas.Hyland
Exactly, UN-Check "Use same settings for Round"
Message 6 of 10
btngpnoy
in reply to: cadbob
Thanks a lot Cadbob . I just got back from adays off I will try what you sent me and let you know the result. Thanks again.
Message 7 of 10
cadbob
Ok, you can use eaither method, the easy way would be as Nick suggested and Make sure you have un-checked use same settings for round. But if you like a custom centerline symbol like myself then the way I suggested would be best. So you have 2 choices! 🙂
Message 8 of 10
btngpnoy
in reply to: cadbob
Cadbob,
Thank you very much for all your efforts helping me. I did the easy way , Nich way just uncheck the, bur I want the custom way like yours. As soon as I familiar with this Fabrication 2014 I will use your custom center line. Once again Thank you very much.
Btngpnoy
Message 9 of 10
btngpnoy
Nick, Thanks for the help it is really appreciated. A big help for us just started 2014 save as a lot of steps and clicks. TY.
Message 10 of 10
siravi.seo
Woowwww.... that's great.
