We are recently upgraded to Autocad 2014 Fabrication (CAD Mech). Before we upgrade to 2014 we can check/see the centerline of the pipe by placing the cursor on the pipe. Now on 2014 it changed to Top & Bottom info elevation instead of CL is there a way to change this back to center line? thanks in advance.
Solved by Nicholas.Hyland. Go to Solution.
See attached PDF for LEVEL BLOCKS. I named mine CL.
Hi btngpnoy,
If you’re not using cadbob’s suggestion of Level Blocks I’d suspect the “Same setting for Round” is enabled as per the attached.
Exactly, UN-Check "Use same settings for Round"
Ok, you can use eaither method, the easy way would be as Nick suggested and Make sure you have un-checked use same settings for round. But if you like a custom centerline symbol like myself then the way I suggested would be best. So you have 2 choices! 🙂
Nick, Thanks for the help it is really appreciated. A big help for us just started 2014 save as a lot of steps and clicks. TY.
