Fabrication CADmep
Join the Autodesk Fabrication CADmep community discussions to help share and receive technical product knowledge, insight, tips and tricks.
Fabrication CADmep
Valued Contributor
0 Kudos
Post 1 of 9
Center line
961 Views, 8 Replies
09-24-2013 03:18 PM
We are recently upgraded to Autocad 2014 Fabrication (CAD Mech). Before we upgrade to 2014 we can check/see the centerline of the pipe by placing the cursor on the pipe. Now on 2014 it changed to Top & Bottom info elevation instead of CL is there a way to change this back to center line? thanks in advance.
Hi btngpnoy,
If you’re not using cadbob’s suggestion of Level Blocks I’d suspect the “Same setting for Round” is enabled as per the attached.
Valued Contributor
0 Kudos
Post 2 of 9
Re: Center line
09-24-2013 03:21 PM in reply to: btngpnoy
still can not find the solution.
Active Contributor
99 Kudos
Post 3 of 9
Re: Center line
09-25-2013 04:26 AM in reply to: btngpnoy
See attached PDF for LEVEL BLOCKS. I named mine CL.
I don't believe you can do today's job with yesterday's methods and be in business tomorrow.
Product Support
9 Kudos
Post 4 of 9
Re: Center line
09-26-2013 02:00 AM in reply to: btngpnoy
Hi btngpnoy,
Nicholas Hyland
Active Contributor
99 Kudos
Post 5 of 9
Re: Center line
09-26-2013 03:34 AM in reply to: Nicholas.Hyland
Exactly, UN-Check "Use same settings for Round"
Valued Contributor
0 Kudos
Post 6 of 9
Re: Center line
09-26-2013 07:05 AM in reply to: cadbob
Thanks a lot Cadbob . I just got back from adays off I will try what you sent me and let you know the result. Thanks again.
Active Contributor
99 Kudos
Post 7 of 9
Re: Center line
09-26-2013 07:29 AM in reply to: btngpnoy
Ok, you can use eaither method, the easy way would be as Nick suggested and Make sure you have un-checked use same settings for round. But if you like a custom centerline symbol like myself then the way I suggested would be best. So you have 2 choices! :smileyhappy:
Valued Contributor
0 Kudos
Post 8 of 9
Re: Center line
09-27-2013 07:13 AM in reply to: cadbob
Cadbob,
Thank you very much for all your efforts helping me. I did the easy way , Nich way just uncheck the, bur I want the custom way like yours. As soon as I familiar with this Fabrication 2014 I will use your custom center line. Once again Thank you very much.
Btngpnoy
Valued Contributor
0 Kudos
Post 9 of 9
Re: Center line
09-27-2013 07:38 AM in reply to: btngpnoy
Nick, Thanks for the help it is really appreciated. A big help for us just started 2014 save as a lot of steps and clicks. TY.
