Fabrication CADmep
Join the Autodesk Fabrication CADmep community discussions to help share and receive technical product knowledge, insight, tips and tricks.
Fabrication CADmep
Active Member
cvidovcich
Message 1 of 9 (584 Views)
Button Mapping
584 Views, 8 Replies
04-03-2014 07:06 AM
I've set up the button mapping to work fairly well with both round and rectangular HVAC duct. My problem is the transition between the two. I cannot find the correct combination of buttons to enable a tap (any kind) out of a rectangular duct when using design line. In all situations, design line leaves a gap in the rectangular duct around where the tap should be and then has the perpendicular branch of duct placed inside of this duct (see attached image). Can anyone point me in the right direction to fix this issue? Thanks.
I don't know what's going on here. I replied once and then my post disappeared after a few minutes. I tried posting again and it just didn't do anything. So I am trying again for the third time... hopefully it works.
CID = Custom ID Number
It's just a way of identifying the items.
Edit: (added comment that was in original post that disappeared)
In your case the real CID is 345. Someone has overridden it to 1020.
I tried CID 345 here and it worked fine. So maybe your item just need some default values changed, or maybe it is corrupted.
If you want you can try posting your itm file, or at least a screen shot of the dimensions tab.
I changed the CID to 345 and the taps are now working. I'm not sure where the other number originated.
Thanks a lot for your help.
Contributor c2k
c2k
Message 2 of 9 (527 Views)
Re: Button Mapping
04-14-2014 09:31 AM in reply to: cvidovcich
What have you tried?
The following should work:
Button Code = RedILTee
Alternate Codes = Straight, RedInLine, Tap
Obviously change the Alternate codes to match your specific codes in use.
Active Member
cvidovcich
Message 3 of 9 (521 Views)
Re: Button Mapping
04-14-2014 09:42 AM in reply to: c2k
I've tried;
Straight, Tap, RedInLine
Tap, Redinline
Redinline, Tap
straight, redinline, tap, straight
At this point, I'm leaning towards the taps somehow being corrupted. Perhaps the taps that I am using don't have the necessary connectors that design line requires. Is this a reasonable assumption?
Contributor c2k
c2k
Message 4 of 9 (519 Views)
Re: Button Mapping
04-14-2014 09:50 AM in reply to: cvidovcich
I don't think connectors are an issue, but it is possible that the CID you are trying isn't supported.
What CID(s) for the tap have you tried?
Active Member
cvidovcich
Message 5 of 9 (518 Views)
Re: Button Mapping
04-14-2014 09:53 AM in reply to: c2k
For the tap I would like to use (Conical spin in) the CID is 1020 (Based on Pattern 345).
What exactly is the CID?
Contributor c2k
c2k
Message 6 of 9 (486 Views)
Re: Button Mapping
04-14-2014 10:37 AM in reply to: cvidovcich
Active Member
cvidovcich
Message 7 of 9 (486 Views)
Re: Button Mapping
04-14-2014 10:38 AM in reply to: cvidovcich
Contributor c2k
c2k
Message 8 of 9 (482 Views)
Re: Button Mapping
04-14-2014 10:39 AM in reply to: cvidovcich
No problem. Glad it's working now.
Active Member
cvidovcich
Message 9 of 9 (481 Views)
Re: Button Mapping
04-14-2014 10:41 AM in reply to: c2k
I was wondering what happened as well. I received emails saying that you posted, but couldn't find anything on the forum.
