Fabrication CADmep Forum
Welcome to Autodesk’s Fabrication CADmep Forums. Share your knowledge, ask questions, and explore popular Fabrication CADmep topics.
Layout dimensioning scaled
5 REPLIES 5
Carl_mgfx
471 Views, 5 Replies
Good Day
I have created a duct run and when dimensioning it in the layout the dimentions are "scaled" according to the VP Scale.  Below I'll explain and attached is an image..
Duct length = 7120
Terminal = 600
VP Scale = 70
Duct Dimension on layout = 101.71
Terminal Dimension on layout = 8.57
I tested this with VP scale of 100 and got a domention of 6 for the terminal.
Is this just a system variable/setting?  I haven't come across this problem before.
PS: There is no scaling set in the Dimension Style.
Kind Regards
Carl van Rooyen
Application Engineer
Inventor 2019, Vault 2019,
HP ZBook 15u G4, Win 10 64Bit (ver 1709), i7-7500U, 16 GB Ram
Intel HD Graphics 620 with AMD Firepro W4190M
5 REPLIES 5
Carl_mgfx
in reply to: Carl_mgfx
Just to add to this I have attached the file in question.  I am using CADmep 2014 SP2 run in AutoCAD 2014 SP1.
Kind Regards
Carl van Rooyen
davidronson
I get 600 for both 1:70 and 1:100, I am running 2014 SP2b
I didnt adjust anything from your file. Perhaps your pick point was off??
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
Carl_mgfx
in reply to: davidronson
Did you manage this by adding dimensions to the layout (paper space) or model space? I see in my previous post I said SP2, it is SP2b that I have installed. I have tried this on another PC and get the same results and explained above.
Kind Regards
Carl van Rooyen
davidronson
In layout tab from your drawing. I double clicked into the viewport, then did spooldim.
Carl_mgfx
Thanks. I will try that and see how it works.
Kind Regards
Carl van Rooyen
