Hi All,
I am searching in vain for the location of weather data files for Ireland.
Can anybody please suggest where they are now available?
Your help would be most appreciated
Many thanks,
Ian
...and from any where in Spain? i have to introduce it from a Meteorological Statistics with the Convert weather tool, it´s easy and you can specify the location you want. Good luck
The Energy Plus database is pretty good, and the EPW file format coverts very easily to a .wea.
Just drag and drop the EPW into either Weather Manager or Weather Tool, and save it as a .wea
http://apps1.eere.energy.gov/buildings/energyplus/cfm/weather_data.cfm
Ireland has about 7 locations. If you are on the coast, find one along the same coast. Inland, find one inland and then check the difference between temperature, rain, etc, and scale your data up or down as needed.
JG
Hello AgengPiandel,
Interestingly, there are no .epw available for Indonesia on the E+ website, which is quite surprising.
Do you have access to other source of hourly weather data? Universities and airports typically carry some weather data.
If you have hourly data in a spreadsheet format, you can import that into the Weather Tool.
Let me know what you can get.
Cheers,
Hello mandanyeX5UHR,
Unfortunately, no. The EPW weather file website still has no data for Indonesia The closest ones are Kushing on Borneo, as well as Brunei.
What city are you looking weather data for?
Cheers,
hello @Pennetier1
Yep i've only found Kuching (in Malaysia) as the closest one to Medan (Indonesia) that i'm looking for the weather data.
I 'll maybe use it and see how it works but it is really boring to do it that way
