Ecotect
Ecotect
Active Member
0 Kudos
Post 1 of 3
Usging Ecotect to simulate artifical lighting in Radiance
2245 Views, 2 Replies
12-19-2010 10:04 PM
I am having problems simulating artificial lighting in Radiance when using the calculation wizard for Radiance.
Eventhough I at the final step specify to generate the light automatically from the pull down menu, my radiance simulations do not contain any artificial light, but only daylight.
When simulating the artficial light levels within Ecotect everything works just fine.
I would be very grateful for any feedback
The light fixtures IES photometric data is not defined in radiance
you need to convert your IES photometric data to the radiance format.
Try using the IES2RAD utility.
Here are a couple of links for you to check out.
http://radsite.lbl.gov/radiance/man_html/ies2rad.1.html
http://www.yichunhuang.com/teaching/ecotec/teaching_ecotec_other.html#ies
Fabian
0 Kudos
Post 2 of 3
Re: Using Ecotect to simulate artificial lighting in Radiance
12-20-2010 05:02 PM in reply to: christian.bosselmann
Fabian
Active Member
0 Kudos
Post 3 of 3
12-20-2010 05:25 PM in reply to: FabianPosadas
Thanks Fabian
merry christmas
