What did I wrong, why the is no significant difference in distribution of lux values through the interior, but the whole room has the same value of lux and the color is constant yellow? Please give me some advice, I attached the visualisation of my results
Hi Cabalakornelia,
It appears that your scale needs to be re-adjusted. There is a option in the Analysis Grid control panel (the little arrow by the Contours entry box) to fit your scale to your calculated values and I am suspecting that is your issue.
Try it and see if that works. If it doesnt work...
Double check that you have indeed a roof on your zones. I am sure you do, or else you would still have some variations.
Did you use the Daylight Factor calculations or was this sent to Radiance and brought back to Ecotect?
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Cheers,
