Hi, erinlilli,
I am experiencing the same problem, although I am using SI units. Major changes in envelope and fenestration reduce hardly some C degrees in temperatures or a few Watts in heat gains. I just wanted to know whether you worked it out by changing units. Did it work for you?
Thanks and good luck.
Oscar.
