Hello ewerybody..
does somebody has clue, what means this error message ??
my ecotect was sometimes falling down, even during counting cumulative values of it was freezing.
i need to sort it today.. i do my master thesis at ecotect
.. Rich
this looks like Ectocet's wasn't installed correctly try uninstalling it and installing it again.
no no .. I have found the problem..
the 3D MESH was imported form Autocad by dxf, or insecond case - from google sketchup
- and there are not only "surfaces" but also "lines" which did this strange view..
- I had to display the surface vectors, where i can find the position of this lines (it shows also the vector in the line-direction)
- delete them.
now will last only surfaces and ewerithing shows how it suppose..
