Ecotect Analysis Forum (Read Only)
2john6
384 Views, 1 Reply
Solar Noon bug?
Has anybody tried the Solar Noon option under 'set current time and/or location'?
It seems the sun's position flips 180 degrees over to the North instead of South.
All the best,
John
1 REPLY 1
Patrick_Villella
in reply to: 2john6
John,
I get the same incorrect result as well. The 'Solar Noon' option has a major glitch. Sunrise and sunset work just fine, but as soon as you refresh the view after using Solar Noon, the sun jumps to the northern sky and is no longer connected to the daily sun path at all (just like in your image.)
Sadly, this bug has not been fixed in Ecotect Analysis 2011 either.
While a bit disconcerting, it's easy to overcome. What I do is to go ahead and use the Solar Noon option, which sets my time for me. The time it calculates, say 12:31 PM for Phoenix AZ on the 3rd of April, appears to be pretty accurate (give or take 5 minutes, according to recent almanacs.) The sun position freaks out, but as soon as I change the time slider manually, it corrects itself. Then I manually type in 12:31 PM and it works like a champ.
Patrick Villella, LEED AP Edited by: Patrick_Villella on May 1, 2010 2:31 AM
