i am trying to figure out what could be causing the lengthy calculation time for the attached model. the geometry was exported from rhino as polgyons (obj file). i set up the model to calculate the incident solar radiation (using the calculation wizard) - for current time - cumulative value - selected objects. after almost 2 hours of calculation time - i get no indication for % complete.
i wouldn't consider the model to be too complex - but is this the kind of calculation time that i should assume for such a model?
thanks in advance.
sean
