Ecotect
New Member
DirkAnderson
Message 1 of 3 (304 Views)
Silent Import
304 Views, 2 Replies
07-15-2009 02:31 AM
I'm importing gbXML data into Ecotect via LUA "cmd("model.import C:\\Database\\Data_GH.xml")" - all works fine, however I wanted to import the data in without any dialog box showing up as I need Ecotect to run in the background. Is there any command to do this?
Dirk
New Member
DirkAnderson
Message 2 of 3 (304 Views)
Re: Silent Import
08-07-2009 07:58 PM in reply to: DirkAnderson
almost a month passed and not one response - great community here.
Basically I'm writing a plugin that connects Grasshopper (Rhino Parametrics) with Ecotect to teach for a Sydney University course and since there's an annoying Ecotect dialog that pops up with gbXML import, it looks like my only option for a silent interface is to basically re-create a LUA script within Grasshopper that generates Ecotect geometry.
If anyone else has any other interoperable tips or hints it would be much appreciated.
Thanks.
New Member
2090015
Message 3 of 3 (210 Views)
Re: Silent Import
03-07-2012 09:07 AM in reply to: DirkAnderson
My dear friend...I had the same problem when I was doing my master thesis. The only solutions Ißve found are:
or you send a sendkey...to press the ok button
or you generate the geometry directly withou imports...
so far no other "miracle"...
Post to the Community
New Post
