Ecotect Analysis Forum (Read Only)
problem with licensing Ecotect
1 REPLY 1
marco_baik
1151 Views, 1 Reply
I had to reinstall ecotect after uninstalling it and when I try to submit the (student license numbers) in the new installation it tells me 'cannot license the product because there is another version of ecotect already installed' (but there isn't any). Could comeone help me?
1 REPLY 1
TravisNave
in reply to: marco_baik
It's probably stuck in the installation registry.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Autodesk Forums:
