Ecotect
New Member
mlebech
Message 1 of 1 (383 Views)
Import Radiance file in ecotect - Problem
383 Views, 0 Replies
06-06-2012 03:17 AM
I am quite used to work with ECOTECT for a long time, nevertheless I have a problem that starts to occur now. We design our buidling with a specific software and exporting it to ecotect in order to run the lighting analysis and optimization. For that we used to export our model from our software to ecotect in radiance file (*.rad), now Ecotect seems to read our model but it doesn't show something and the object inspector has just the name of the radiance file without attached objetcs. What is strange is that if we read with DAYSIM the raidance file, all seems OK. Do you have an idea if there is a patch for of ecotect for the new radiance software? We use ecotect 2011 as version.
If someone has already encouterd this trouble, I would be glab to discuss with him.
Thank you for help,
Maxime
