Hi the truth is out there :-).. écotect is actually using a dynamic simulation that uses a value for a building with ligth and heay materials Ecotect chooses one of the values depending on the responsfactor.
To cal culate see here I actually made a excel sheet for values in Ecotect. But you can see the formula here.. Its really the key for having the rigth temperature cal http://www.pilkington.com/resources/solargainfactors.jpg
I would like to eksplain it in more detail send me an email..
Cheers..
HI nielsthuesen,
but where i can find the SWSC and LWSC factor in the equation of the tabel thath you linked??
thanks!
Antonio
Hello joyri_nuno7,
Alt Solar data from manufacturer is scarce.
Have a look at this previous post for some insights.
I hope that helps.
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Cheers,
Hello Asbjorn Levring.
Could you please send me more information about the calculation you said and to get the thermal values of a crystal and enter them to ecotect?
Best Regards, thank you.
