Please help me to make this geometry attached in ecotect.All dimensions in mm.
Thanks in advance,
Rrgards,
Hema
Solved by Pennetier1. Go to Solution.
Hello hemakbm,
See attached the geometry.eco
I hope this helps. It is built simply by using the zone tool. The angle was done using a simple line that was rotated 7* and have the geometry of the zone follow that angle.
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Cheers,
