Ecotect Analysis Forum (Read Only)
gbXML from ARCHICAD to ecotect
2 REPLIES 2
catherine.massart
2996 Views, 2 Replies
I start using ecotect and I'm doing some tests.
When I want to import a gbXML file (created from ARCHICAD), I get this message:
"WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
And it does import nothing (0 spaces, 0 surfaces, 0 ...)
What's the problem?
Thanks for helping
2 REPLIES 2
I've the same problem.
One of my costumer has ArchiCAD and would like to import IFC data into Ecotect, but the system shows that there is a beta versión. Are you going to improve this issue?
Thanks in advance.
Hi, did you find any solution to tihs problem because i am having the same problem and cant find anything about this on internet?????
zohaib ali kalani.
