Ecotect
New Member
catherine.massart
Message 1 of 3 (2,104 Views)
gbXML from ARCHICAD to ecotect
2104 Views, 2 Replies
02-21-2011 07:48 AM
I start using ecotect and I'm doing some tests.
When I want to import a gbXML file (created from ARCHICAD), I get this message:
"WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
And it does import nothing (0 spaces, 0 surfaces, 0 ...)
What's the problem?
Thanks for helping
rafael.rodriguez
Message 2 of 3 (1,960 Views)
Re: gbXML from ARCHICAD to ecotect
04-28-2011 07:33 AM in reply to: catherine.massart
I've the same problem.
One of my costumer has ArchiCAD and would like to import IFC data into Ecotect, but the system shows that there is a beta versión. Are you going to improve this issue?
Thanks in advance.
Member
zohayb_85
Message 3 of 3 (1,476 Views)
08-17-2012 06:29 AM in reply to: catherine.massart
Hi, did you find any solution to tihs problem because i am having the same problem and cant find anything about this on internet?????
zohaib ali kalani.
