Ecotect
Ecotect
New Member
sharanya-te
Message 1 of 11 (2,894 Views)
gbxml error in Ecotect 2011 while importing from Revit 2013
2894 Views, 10 Replies
07-05-2012 09:03 PM
When I want to import a gbXML file in ECOTECT 2011 - (created in REVIT 2013), I get this message:
"WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
And it does import nothing (0 spaces, 0 surfaces, 0 ...)
What's the problem? How can this be solved?
Thank you
New Member
avgustin.nejc
Message 2 of 11 (2,809 Views)
Re: gbxml error in Ecotect 2011 while importing from Revit 2013
08-09-2012 06:25 AM in reply to: sharanya-te
I have the same probelm....
anyone knows a solution for this problem??
please HELP me....
New Member
349-35828718
Message 3 of 11 (2,735 Views)
08-24-2012 01:23 AM in reply to: sharanya-te
Same problem and the info required is urgent!
Any solutions? Anyone...
Member
davidmorg
Message 4 of 11 (2,711 Views)
08-27-2012 03:48 AM in reply to: sharanya-te
I have the exact same problem. It is something to do with Revit 2013 as I never had any problems importing from Revit 2012.
New Member
jopetit
Message 5 of 11 (2,699 Views)
08-29-2012 08:00 AM in reply to: sharanya-te
I have the same problem, with revit 2013.
With 2011 it works
I hope some answer from somebody
thanks
New Member
dmorgan
Message 6 of 11 (2,688 Views)
08-30-2012 08:50 AM in reply to: jopetit
Member
davidmorg
Message 7 of 11 (2,680 Views)
08-30-2012 09:04 AM in reply to: dmorgan
New Member
sberges
Message 8 of 11 (2,383 Views)
10-24-2012 02:25 PM in reply to: sharanya-te
This is still not working for me can I get a step by step instruction please? What do I do once I open the gbXML in notepad onwards? I still receive an error message in ecotect.
Thanks!
New Member
nfa070
Message 9 of 11 (2,369 Views)
10-25-2012 12:04 AM in reply to: sharanya-te
Thanx a ton mate.. Cheers!!
New Member
Naveen10
Message 10 of 11 (273 Views)
06-24-2014 04:38 AM in reply to: nfa070
Hi I am facing the same problem (IFC Warning while importing "revit 13 exported gbXML file" to  Ecotect)...Plz help
