Ecotect
Ecotect
New Member
1 Kudo
Post 1 of 11
gbxml error in Ecotect 2011 while importing from Revit 2013
3098 Views, 10 Replies
07-05-2012 09:03 PM
When I want to import a gbXML file in ECOTECT 2011 - (created in REVIT 2013), I get this message:
"WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
And it does import nothing (0 spaces, 0 surfaces, 0 ...)
What's the problem? How can this be solved?
Thank you
New Member
0 Kudos
Post 2 of 11
Re: gbxml error in Ecotect 2011 while importing from Revit 2013
08-09-2012 06:25 AM in reply to: sharanya-te
I have the same probelm....
anyone knows a solution for this problem??
please HELP me....
New Member
0 Kudos
Post 3 of 11
08-24-2012 01:23 AM in reply to: sharanya-te
Same problem and the info required is urgent!
Any solutions? Anyone...
Member
2 Kudos
Post 4 of 11
08-27-2012 03:48 AM in reply to: sharanya-te
I have the exact same problem. It is something to do with Revit 2013 as I never had any problems importing from Revit 2012.
New Member
0 Kudos
Post 5 of 11
08-29-2012 08:00 AM in reply to: sharanya-te
I have the same problem, with revit 2013.
With 2011 it works
I hope some answer from somebody
thanks
New Member
0 Kudos
Post 6 of 11
08-30-2012 08:50 AM in reply to: jopetit
Member
2 Kudos
Post 7 of 11
08-30-2012 09:04 AM in reply to: dmorgan
New Member
0 Kudos
Post 8 of 11
10-24-2012 02:25 PM in reply to: sharanya-te
This is still not working for me can I get a step by step instruction please? What do I do once I open the gbXML in notepad onwards? I still receive an error message in ecotect.
Thanks!
New Member
0 Kudos
Post 9 of 11
10-25-2012 12:04 AM in reply to: sharanya-te
Thanx a ton mate.. Cheers!!
New Member
0 Kudos
Post 10 of 11
06-24-2014 04:38 AM in reply to: nfa070
Hi I am facing the same problem (IFC Warning while importing "revit 13 exported gbXML file" to  Ecotect)...Plz help
