Ecotect
Member
alighozmit
Message 1 of 3 (437 Views)
Energy consumption increase as a result of insulating floor
437 Views, 2 Replies
06-21-2012 08:17 AM
I am doing research on the energy consumption profile of residences. Applying insulation to roofs and walls which decreases their U-Value, reduces the energy consumption as expected while, insulating floor has completely negative effect on heating and cooling load and increase them significantly. What can be the reason behind?
New Member
Jesperhildeandersen
Message 2 of 3 (422 Views)
Re: Energy consumption increase as a result of insulating floor
07-02-2012 02:13 AM in reply to: alighozmit
Can u maybe upload a file ?
Member
alighozmit
Message 3 of 3 (416 Views)
07-02-2012 03:28 AM in reply to: Jesperhildeandersen
I tried to upload files but .ECO extensions are not acceptable!!! I tried .XML files but material assignments are not properly exported.
If you draw any simple zone, assign ConcFlr_Carpeted_Suspended as floor type analyze it then, assign ConcSlab_OnGround as floor tyoe which has comparatively low U-Value, you will see that the annual energy consumption increases surprisingly.
