Ecotect Analysis Forum (Read Only)
Ecotect shows no significant analysis over options
0 REPLIES 0
Message 1 of 1
1134 Views, 0 Replies
Dear All,
whether any of you encountered the same problem as described below - and willing to share yoursolution in this forum
I am using 2012 revit version to produce options in bgXML files  for analysis in ecotect and green building studio
There are 5 options curtain wall panel configuration as described below, floor to floor height of typical storey is 4250mm
The analysis result did not give any clear direction. Ecotect produced exactly the same result accros the board, while Green Building Studio analysis showed confusing result
Option 1 with an additional row of fin actually INCREASE the energy use.
Option 3,4 and 5 shows no differences
the gbXML files is attached.
Are those BIM analysis tools really work for you?
Thanks in advance
Michael
Options
Description
Ecotect Daylightng Factor
Ecotect
Daylight Factor
GBS
Electric (kWh)
GBS
Fuel (MJ)
1
31st Storey- w Double Fin.xml
Double fins applied, each at 2575mm and 3134mm AFFL respectively ----------------
No significant change detected
539,719
20,283
2
31st Storey- w Fin 2.xml
Single Fin was applied, at 3134mm AFFL,
using fin material as floor family for analysis purposes ---------------
539,225
20,243
3
31st Storey -Fritted Panel 2.xml
Fritted pattern applied on glazing panel, the stripes cover 440mm glass panel top height, material assignment stone ------------------------
600,318
20,194
4
31st Storey -Fritted Panel -wall.xml
Fritted pattern applied on glazing panel, the stripes cover 440mm glass panel top height, material assignment wall family, ceramic------------------------------
600,318
20,194
20,194
5
31st Storey -Plain Panel.xml
Plain curtain wall unit with vision and spandrel panels
600,318
20,194
0 REPLIES 0
