Ecotect Analysis Forum (Read Only)
Ecotect license error
1 REPLY 1
Fabioing8
1052 Views, 1 Reply
Hi evrybody
I've got Autodesk Ecotect Analysis 2011 student version (my license will expire in September 2015). Evrytime i try to open the softwere it appears an error message wich tells that "the product you are using requires a serial number and a product key to continue", if i enter my product information Ecotect works perfectly and it appears a new message that tells "a previously registreted and activated code license for your product was found on this computer and is now in use". But when i close the softwere and i try to restart it, the error message appears again!
What i have to do?
Thanks a lot
1 REPLY 1
maryamm
in reply to: Fabioing8
That happens to me and to my classmates too. I think it it a bug for student version. what i did was i copied and pasted the serial numbers on a sticky note on my desktop or in a txt file so it is easy to access.
