Hi, I would like to ask if there is a possibility to download student version of Ecotect Analysis 2011 for windows-64 bit system? and if I had already installed version of 32-bit system on my 64-bit operating system can some problems may occur during using Ecotect?
Solved by Pennetier1. Go to Solution.
Hello Cabalakornelia,
As far as I know - but I could be wrong - Ecotect has always been a 32 bit software.
I have used it for over 10 years on my 64 bit machine and have not experienced issues related to this, so you should be ok.
I am using Windows 8.1 64 bit with Ecotect 32 bit and it installed and works like any other 32 bit software on 64 bit machine.
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Cheers,
Hi Autodesk,
Happy new year!!!!!!!
I'm a student and I would like to have the software ECOTECT but you don't have the version for windoms 64bits.
Please, will you give us this version?
Thaaaaaanks.
Léon
Likewise and welcome to the community Léon!!!!
As mentioned above, you should be able to install the 32 bit version of Ecotect on your 64 bit machine.
Merci beaucoup pour la réponse Cabarakornelia.
Je l'ai installé la semaine dernière mais j'avais eu peur que ça détéiore mon système de 64 bits. Du coup, je l'ai désinstaller mais franchement ça a marché. J'avais un doute seulement sur le long terme.
Je vais uiliser celui là alors.
Encore merci.
Aurevoir
You're most very welcome!
